HondaTwins.net
General Discussion
Smaller Twins: 125-200 cc's (CA,CB,CL,SS) '59-'76
250's and 305's (CA,CB,CL) - 1959-1968
250's, 350's and 360's (CB,CL,CJ,SL) - 1968-1976
DOHC 450's and 500's (CB,CL) - 1965-1976
SOHC Twins 125/250/400/450(CB/CM/N/Rebels) '78-'08
Classifieds
Vendor Member Section
Want to Grow Your Business? Learn more about becoming a Supporting or Premium Vendor
Forum Support
Off Topic Lounge
Latest Posts
I have a 1974 CB450. It ran when I bought it. I have rebuilt the carbs (I took them apart a second time to make sure I didn't do something wrong) and added new throttle cable, petcock, and fuel lines. Now the engine starts when I spray starter fluid in the carbs but it wont stay running. I'm...2 replies 36 views
I just bought a 79 CM185, that's on a pretty good shape. The main problem is the previous owner put a 12 volt battery on it. He said he rode it for a few minutes and it died. I put a 6 volt battery on, and the starter cranks, the high beam comes on and the high beam light on the instrument panel...7 replies 101 views
I recently bought a 1982 Honda CM 450 E. While it was running, it was not running well at all. Spent quite a bit of time on the carburetor finally figured out the main primary and secondary jets were switched and now it runs great. I do have a question if anybody has suggestions for tires, I am...1 reply 33 views
Hi, at this time I'm very happy to ride my track bike with the engine Honda CB 125 twin (1978 as the pilot). But on the other hand against large engines I lose ground :( , my regulation allows me use an engine up to 250cc.why not a 185cc. Following my research I find the work of Michael A...8 replies 2K views
